How do I move adrawing view from one sheet to another
derek_westwood
Member Posts: 35 ✭✭
I have created various drawings from (right click on part) create drawing of (part name)
All drawings are now called (part name Drawing 1) and I cannot move views from sheet to sheet. As only sheet 1 exists and move to sheet option is greyed out
Add another sheet with in each drawing. Then you can move view to another sheet.
https://cad.onshape.com/help/Content/drawings-sheets.htm?tocpath=Drawings|_____3
You can also right click on a view and select "move to sheet"
Hi,
Is there a way to move a View to a Sheet in another Drawing or a Sheet from one Drawing to another Drawing ?
Found myself in a self inflicted mistake, not fatal.
Thank you, Jim0 -
I don't think there is. However you can duplicate a drawing and then delete what you don't want out of either one.0
