Transformation of a surface in a loop fails
MaxFlow
MaxFlow Member Posts: 6 ✭✭
I am running the following sequence
1. transform+copy an existing surface 5 times
2. Add the new surfaces an attribute "Slicer"
3. Delete all surfaces with an attribute "Slicer"
4. Got back to step 1.
During the first iteration everything works fine, however during the second iteration transform fails with "Cannot Resolve Entities". I checked that my delete operation does not delete the original surface, only copies. Does anyone have an idea what the problem might be?
     var distance=0;
        for ( var i=1;i<5;i=i+1)
          println(i);
          distance=0;
          for ( var count=1;count<5;count=count+1)
            distance = distance+2+6;
            print("-");
            println(count);
            //print("---");
            //println(definition.xslicer);
            transform(context, id + i+count+"transformx"+i+count, {
                                "entities" : definition.xslicer,
                                "transformType" : TransformType.TRANSLATION_3D,
                                "dx" : distance*millimeter,
                                "dy" : 0*millimeter,
                                "dz" : 0*millimeter,
                                "makeCopy" : true
            setAttribute(context, {
                    "entities" : qMatching(definition.xslicer),
                    "name" : "Slicer",
                    "attribute" : "Slicer"
        try
        opDeleteBodies(context, id + "deleteBodies", {
                "entities" : qHasAttribute("Slicer")
        catch
        println("Error - opDeleteBodies");
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,092 image
    What does this script do? Hard to tell without access to the full thing, but your id construct in transform is a little odd and I’m not sure I would rely on qMatching.
  • MaxFlow
    Hi Neil,
    The overall goal to create a surface texture.
    1. Split all faces along Z
    2. Split all faces along X
    3. Split all faces along Y
    4. Move faces randomly
    For splitting purposes, I create several, temporary copies of a pre-defined surface. The temporary copies are then deleted and the process starts again.
    The problem is that the process works for only one iteration. transform() fails during second iteration.
    I created a simplified FS to debug this issue (see the "Sandbox" FS - https://cad.onshape.com/documents/3cfff268f3889341b02464a8/w/85e63e5bbddd5c2dace86f37/e/feb92511a4af3a77e2661137), however I struggle with root causing the issue.
  • NeilCooke
    This will fix your script so far, but I can't help but think this will not work as you expect. Using qMatching and setAttributes is not the best strategy IMO.
    var distance=0;
              println(i);
              distance=0;
                print("-");
                println(count);
                transform(context, id + i+count+"transformx", {
                                    "makeCopy" : true
                        "entities" : qCreatedBy(id + i+count+"transformx"),
                        "name" : "Slicer",
            try
            catch
  • MaxFlow
    What strategy would you suggest?
  • NeilCooke
    Hard to say - I'm trying to picture in my mind what a part would look like after applying this script. The loop seems to do the same thing each time?
