Move parts to one another in part studio? Like the fasten mate in assemblies
kai_svensonkai_svenson Member Posts: 2 EDU
edited January 2021 in Community Support
Hello, so with the question in mind, take the following example:
How do I place the blue cylinder on top of the vertical grey cylinder if I don't know the exact distance to translate it? (This is just an example, I know that there are other ways to put a cylinder on top.)
Thank you very much in advance!
    wayne_sauderwayne_sauder Member, csevp Posts: 478 PRO
    You should be able to do that with the transform by mate connector tool.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,402
    Best practice is of course to do this in an assembly or model the parts in the correct locations in the Part Studio.
    T_RathierT_Rathier Member Posts: 43 EDU
    Relocate the sketch in the second part.
