How to create a low-poly object in Onshape
vikram_koli595vikram_koli595 Member Posts: 31 EDU
edited January 2021 in Community Support
I would like to create these types of low poly shape in Onshape. It seems difficult to model because all of the faces point in random directions. Any help would be accepted. Thanks!
  • MichaelPascoeMichaelPascoe Member Posts: 2,925 PRO
    edited January 2021 Answer ✓
    Here is one approach you might try:
    • Sketch the base
    • Sketch front plane points (or another custom plane)
    • Sketch side plane points (or another custom plane)
    • Fit spline one line at a time
    • Fill each triangle
    • Fill the base
    • Shell the faces that you want to be left open
    If you do these kinds of parts a lot, consider having a custom feature made for this.
    RENDERCAD
    RENDERCAD
  • EvanReeseEvanReese Member, Mentor Posts: 3,004 PRO
    check out the Convex Polyhedron feature by @konstantin_shiriazdanov.
    Also, a note for the workflow above: you can loft a straight line to a point, and skip the splines, since you can use the edge of the loft before. (pro tip: Usually, this would make your UV curves all converge at the point, but since it's planar, Onshape recognizes that builds it as a trimmed rectangle).
    • Sketch the base
    • Fill the base
    RENDERCAD
    RENDERCAD
  • vikram_koli595vikram_koli595 Member Posts: 31 EDU
    Thanks for the help! This is a great solution. I will model one of these shapes and will post the end result in the chat! Thanks again!
    That's pretty sweet.
    RENDERCAD
    One question, When you say Loft a line to a point, do you mean this?
    yep! that's exactly what I mean. I also realized that I could pretty easily modify my Freeform Spline feature to be a 3D points feature, which I've wanted from time to time, so I just converted it real quick. You can add it here to make your points. I'll make an icon and tidy it up sometime soon and post in the main group, but it seems to work as-is.
    Thanks for the resources! I will first finish the model and then take a glimpse into computer-generated models. Thanks
    Another question. It keeps giving me an error once I have made a full rotation of bottom lofts. I'll include a gif.
    Oh Fixed The problem. Here is how.
    edited January 2021
    I believe that is from 'non-manifold' geometry. The surface cannot be joined at a single point. Once you create a new surface and then 'add' final it creates a full edge joint.
    You may follow this thread and related.
    www.accuratepattern.com
    Thanks for all of the help! I have finished the model. Here are some pics and a gif
    Nice work!
    RENDERCAD
    Thanks!
    Nice! looks good.
    Thanks!
  • roman_jurt190roman_jurt190 Member Posts: 88 EDU
    Just used a Variant of this workflow and thought I'd share it:
    - Make a base-sketch with lines (as a start for the lofts)
    - Make 3D-Points by using @Evan_Reese  3D Points FS
    - Use lofts "line to point" (ending each feature with [shift]+[return] opens a new loft-feature immediately!)
    - Make a paper-thick sheetmetal
    This process gives you free, fast and live 3d-manipulation of all points at the same time.
    Adding new points to the "mesh" is still a huste, though.
    This is potentially a fast process for prototyping and packaging:)
    Have a look:
    https://cad.onshape.com/documents/bbec0b3d977212a847973244/w/fcc4f6d8f58fe6b605d9e91e/e/4d91b54655dd25f7b6a89c92
