Hide All Non Solids?? Or similar to "Section View" a "Solids Only View"?
christopher_owens
Posts: 235 ✭✭
Hello! I run across this a lot! When I want to do a "screen grab", I have to do a lot of selecting to hide planes, sketches, surfaces, etc. I was thinking of creating a "Level" that all those were on and being able to "Blank" that "Level". Easiest way I have found (so far) is to Select a Plane and pick "Hide Other Planes" then pick that Plane again and select Hide. then repeat that for the other "non-solids" Maybe, similar to "Section View" there could be a "Solids Only View" that you could turn on and off??! One pick, screen grab, one pick back to "All Displayed".
You can also hide/show all of the planes with the 'p' key.5
I would like to see this functionality as part of named views. When saving a view, select to save also hide/show state of things.
//rami7
Actually that would come in handy when doing something that I only need the solid bodies to do. Clean up the screen clutter!0
For current example! I want to modify the diameter of the blue "hub". When I try to double-click on it, various "non-solids" get selected! Yes, do a right-click, select other, and get a long list to scroll through or scroll through the Feature List and find the sketch that created the part. "View Solids Only"!
Ok... as I learn "new things". Move the mouse over the sketch line in the "hub" sketch and when it highlights double-click on it!! Now the dimensions for that come up! As long as it isn't hidden... still would like "View Solids Only"!0
Instead of hiding planes,sketches and surfaces separately.. You can select one plane,one sketch and one surface then if you right click there is a option to hide other plane,sketch and surface...after doing this again right clicking we are not having the option to hide selected entities.. We hope that option will be there in next version..0
Thanks @Narayan_K ! I did do a "drag window" and selected multiple sketches at once, and then "right-clicked" to hide those.0
//rami7
