N key not working for normal to
lowell_yoas
Posts: 2 EDU
What or where do I go to get the shortcut of N for normal to - to start working?
There is no setting. It should just work.
You need to click on a face/plane so the system knows with respect to what are you viewing normal to. In a sketch, you just need to press N because you are already working on a plane.2
bradley_sauln said:You need to click on a face/plane so the system knows with respect to what are you viewing normal to. In a sketch, you just need to press N because you are already working on a plane.
According to my experience, since the V1.114 update you just have to hover your mouse over a planar face and press N.2 -
Shortcut n does not work in Firefox browser I cant find any solutionA search box opens in the lower left corner when any key is hit it forcing me to use the Chrome browserIt works when Firefox is fresh installed , but after a while the shit reappears0
svenolov_nystrom said:Shortcut n does not work in Firefox browser I cant find any solutionA search box opens in the lower left corner when any key is hit it forcing me to use the Chrome browserIt works when Firefox is fresh installed , but after a while the shit reappearsI think I know why, IIRC it happens because at some point you enabled a feature in Firefox that makes Firefox start a search as soon as you press a key (and it's not in a input focus).See section "Find automatically while typing on a page" on this page: https://support.mozilla.org/en-US/kb/search-contents-current-page-text-or-links .Be sure to uncheck this, I think it will work back.In any case, I'm using Firefox both in Windows and Linux (currently Windows, Firefox version 94.0.2 (64-bit)) and I can confirm N works very well to orient normal to face / place.
2 -
Thanks now the n key works it is a nice feature !!
