Oblique tube link
hi,
i need to draw an oblique tube like the one market by an arrow... i done it, placing two planes (1 and 2) in the middle of the objects to merge. after this i done two sketches with two circle, and after i done a loft...
but this isn't the right way, because loft squeeze itself...
how can i do it in the right way?
Thanks
Thanks
yes. i used sweep for the other pipes that you can see in the picture. i've used 'ortho lines' + sweep. but i can use this solution only with the same or parallel planes, where i use straight pipes. but... if i have two parallel object, and i need to connect it's with a diagonal pipe? like the pics:
Freeform spline by @Evan_Reese
Wire / Pipe by @John_P_Desilets
https://cad.onshape.com/documents/3eaf3e626a7a392b69bfffc7/w/5dca553846afdb7920f2356c/e/cc2eb7eff83819c560163af4
Website: ovyl.io
Instagram: @evan.reese.designs
https://cad.onshape.com/documents/3eaf3e626a7a392b69bfffc7/w/5dca553846afdb7920f2356c/e/b6c5d936315637b3e47a795b
3D spline and Freeform Spline works very well!!!
