Intersect Views (New Custom Feature!)
MichaelPascoe
Member Posts: 2,685 PRO
Intersect Views
https://cad.onshape.com/documents/1755463e12cab51e4a5de51f/w/07865f22b67cc44e473c99a3/e/302fb7288b77057ca30414fb
How to add a custom feature to your tool bar:
11
This is definitely one of my favorites so far.
Hope this translator works
Twitter: @BryanLAGdesign
I have added a "Show behind the scenes" configuration checkbox for the example tab. This should help explain how it works.
Feature Tip!
Here is a new trick I learned today. If your part is identical from the front view and the side view, you can use one sketch for both viewsLearn more about the Gospel of Christ ( Here )
Intersect views has been moved to this location: Intersect views
Update!
This feature has been completely re-written for the Onshape live 2022 contest. Hope you enjoy the update!Learn more about the Gospel of Christ ( Here )
This update is provided by @emagdalenaC2i, thanks C2i for the update!
Update!
- Keep Front reference origin.
- Hide reference lines.
- Sub feature Revolve.
- Sub feature boolean option "New".
https://cad.onshape.com/documents/6c4ae7073bbb41d485299a31/w/a75a42c352a4a591769b844c/e/3fa7aee126526b3c0974a8d5?renderMode=0&uiState=61f8c847698d9a75bc84c786Learn more about the Gospel of Christ ( Here )
