Support creating a fill with guides
rafael_ch
rafael_ch Member Posts: 3 ✭
Hi everybody,
I am trying to create a fill (to make a sailboat hull) using two main curves, and a few curves as guides. I used composite line on the two main curves. Then I created several cut planes and defined a guide on each; in total 5 planes.
When I create the fill everything goes well until I select the last guide - then the fill fails to calculate. It calculates well up to that moment. Anybody could have a look (https://cad.onshape.com/documents/555664279bdf96374299c032/w/fae333e771166be5df7347a9/e/7bc1f37d6bf1750cb0aa3a3e) and give me some indication of what I'm doing wrong please?
I believe I ensured I used the same number of spline points on the guides -If I am not mistaken- believing that this should help creating the fill. Still, no luck.
I would really appreciate any help or guidance on this.
Thanks a lot in advance, with best regards,
Rafa
