<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
Support creating a fill with guides
rafael_ch
Member Posts: 3 ✭
Hi everybody,
I am trying to create a fill (to make a sailboat hull) using two main curves, and a few curves as guides. I used composite line on the two main curves. Then I created several cut planes and defined a guide on each; in total 5 planes.
When I create the fill everything goes well until I select the last guide - then the fill fails to calculate. It calculates well up to that moment. Anybody could have a look (https://cad.onshape.com/documents/555664279bdf96374299c032/w/fae333e771166be5df7347a9/e/7bc1f37d6bf1750cb0aa3a3e) and give me some indication of what I'm doing wrong please?
I believe I ensured I used the same number of spline points on the guides -If I am not mistaken- believing that this should help creating the fill. Still, no luck.
I would really appreciate any help or guidance on this.
Thanks a lot in advance, with best regards,
Rafa
Rafa
Your composite curves are extended past the last profile (actually up the side of back profile) which seems to be disallowed during a loft. Tried a couple options for your shape using a surface then a solid. Best response came from solid loft then shell. The surface loft had trouble thickening the fill at the back.
https://cad.onshape.com/documents/8700a9172ae28ad0d60893b3/w/c2545dfe43c7c6e4618daf80/e/8da1c5104a66043586860941
Cheers Glen3
Cheers Glen3 -
Thanks so much for the explanation help - it looks great!0
