Creating belt between two pulleys
gluebaby
gluebaby Member Posts: 3 ✭
Howdy, I'm sort of new to CAD, but I'm creating a rock tumbler for my sister. I have a pretty basic setup, and so far everything looks alright, and now I'm trying to create a belt between two pulleys.
I've attached an image there. The pulleys look very gear-like because originally I was going to use gears, but I decided to go with a 3D printed timing belt instead. I've tried using curve patterns, manually sketching, etc, but can't figure out a way to generate a belt with teeth that match up with the two pulleys. The document is here: https://cad.onshape.com/documents/1c3f0bc7f43db3702e5291e2/w/16bfc5996eedb58af46b1170/e/4cca6effcc7d9333c9678bd0
If anyone knows how to do this, some tips would be great. Thanks!
