Can I constrain features in a sketch to lines/points in a sketch that is in a different plane?
alec_arshavsky
Member Posts: 4 ✭
Hi everyone, I am trying to constrain a point to be coincident to a line in a perpendicular plane/sketch and I don't seem to be able to do that.
More specifically: I have these two lines coming out of the tetrahedron and would like the endpoints forming the vertices of the orange highlighted triangle in my sketch to be coincident to those lines
Is there a way to do so?
I am open to other solutions for what I am trying to do here as well (hopefully the image shows my intention). I don't know if projecting a sketch onto another plane, for example, would be a viable solution
Thanks for the help!
Optionssteve_shubin Member Posts: 1,066 ✭✭✭✭@alec_arshavsky
seems like you might be trying to project from some point where the oval is ?
The best thing to do is to post the URL or the website address for your document here so people can take a look at it — because sometimes it’s a little hard to understand what people are trying to say
But it sounds to me like you will be able to accomplish what it is you want either by using the Coincident constraint, USE tool, or Pierce constraint. Or if not by using one of these methods, then maybe by projecting it some other way
2
Thank you - the pierce constraint was what I was looking for. Really grateful for your help!
