Stretchy block in assemblies
duncan_thomas
Member Posts: 9 ✭✭
Hi
I don't know if I'm doing something fundamentally wrong, but I'm having trouble getting assemblies to fit together without doing lots of math myself. Sometimes what I really want is a part that can stretch, usually along one axis, to fill a gap - I just know that I want e.g. two pairs of two faces to touch (plainer mate)... Is this sane/possible/likely to be possible later?
If you have a sketch, or a link to a public onshape document, that shows what you are doing it will help people respond.
Generally, all the math is done in part studios, in sketches, via constraints. So I design groups of parts in the same part studio, and instead of giving a 'stretchy' part a dimension in the sketch, I use a coincident constraint or something like it.
So I think that the answer to your question is that it is both sane and possible. Post a little more detail.
5 -
That sounds right. Everything relating to geometry of parts (including geometry driven by other parts and sketches) goes in studios.
A key functionality that's missing is being able to create relationships between part studios (Onshape is working on providing this).
5
5 -
So it looks like I can't do what I want in an assembly, only a part studio. I'll try again using just one part studio. If I can't figure it out today, I'll simplify the design and post up a public document.
Thanks
5 -
Ok, I managed what I wanted (https://cad.onshape.com/documents/4546a85071014a38a3ec5c5a/w/b5b1cc5914e04e0eb78b05eb), thanks.
1
