Taking a 3d surface (STEP File) turning it into a sketch, to use as a template on a different part.
dean_spears301
Member Posts: 2 EDU
How can I take a 3d surface and turning it into a sketch, so I can use it as a template to make mounting post on a different part. Example I have STEP file of a circuit board. I want to transfer the mounting hole of the circuit board to make mounting post on a different part.
Thanks
Dean
Thanks
Dean
The’Use’ command in a new sketch projects edges you select.www.accuratepattern.com0
Try the Use command when sketching on your new sketch plane0
