how to deal with flat panels
david_lang457
Member Posts: 104 ✭✭✭
I tend to do a lot of plywood designs, so I end up with a bunch of rectangles (or rectangles with some pieces missing) of just a few different thicknesses.
Has anyone created tools that can take the 3d parts and easily do things like the following:
1. in a BOM list the dimensions of the parts
2. create an assembly where the parts are all laid flat
3. assemble the flat parts in the assembly into sheets (ideally with a configurable kerf between them) This is a similar problem to nesting parts, but easier in that everything can be considered a rectangle
4. and even more ideally, make it so that all kerfs cut all the way across the configured sheet size
RENDERCAD
In case this isn't obvious, keep in mind that Michael said "a" part studio not "the" part studio. The nesting doesn't have to happen in the same studio that was used to create the parts. You can have as many part studios in a document as you want, or you can have them in a separate document - depending on how you want to manage versions and branching.
FS: Stock Size | BOM (onshape.com)
Here are some example parts with a BOM
You can see you can specify units, and mix units if needed
For plywood, you would want to specify "BAR" as the material type to get fractional Inch values.
Normal use will be as simple and selecting the parts and let it autodetect.
I use one feature per part style
@S1mon is there a way to have the same part in multiple parts studios?
I want it so that when I make a change in one place, the changes show up wherever I am laying the parts flat to nest them. I thought that meant that I would have to do the nesting in an assembly
I've done this manually, but it is a royal pain to rotate lots of parts, set all the tangent constraints to get things flat (and deal with the cases where onshape decides to do something odd and I have to change the tangent direction) , then arrange and set constraints to align them (which still doesn't allow me to take into account the kerf for cutting)
I loaded it into one doc and used it, seems to make no difference (if I create an assembly and load insert things, I see debug data that looks like it's doing the right thing, but I'm not seeing how to add it to the table
https://cad.onshape.com/documents/9d12db31b4a3ab160749d9db/w/803db6308d778ef4cdab0766/e/93fc9bd5f43ebc4806057704
I then tried cloning the example, and that doesn't seem to be working for me either I get 'property not found' column in the BOM with no data
https://cad.onshape.com/documents/f4a4130ff2031c1446b05699/w/569342730494bbce0c5f3964/e/c539f924adec0c8a09be513f
Is this possibly a feature only available to paid users?
I just noticed you are free user.
Ether way, you need to copy the fs document and modify the setproperty() function to point to a property to store the data.
Line 418 of the code.
Being a free user you may have to store the data in an un used property, perhaps title1 or something.
https://cad.onshape.com/FsDoc/library.html#setProperty-Context-map
Also, if you're trying to do the nesting in an assembly, use the "Fixed" mate and just add an offset for whatever you want your kerf to be (you can add these offsets to any mate, actually). These will be a lot more stable when you make design adjustments as compared to tangent mate.
When deriving a part from one part studio to another within the same document, the part will automatically update when a change is made to the original part.
When deriving a part from one part studio to another in different documents, the part will be under the command of the original document's version control. Any changes made to that part in the original document will not persist unless a version of the original document is made, and the linked document is updated in the external document.
chadstoltzfus@premiercb.com
Second comment in this thread...
setProperty(context, {
"entities" : part,
"propertyType" : PropertyType.CUSTOM,
"customPropertyId" : customPropertyId,
"value" : propertyValue
Might you go a step further and post a reply with a revision of the code section that would populate the property "Title1" to copy and paste? Much appreciated!
here is a short clip of all the steps necessary.
copy the document
find row 418
delete 419 also since it's irrelevant unless you are setting a custom property
then delete up to the period '.' re-type the period and let autocomplete show you all of the available properties to save to.
then commit.
if you have the ability to set a custom property, do this instead
go to your company settings
find your custom property, or make one. find the 'copy ID' button to copy it
copy the document
find row 419
replace the customPropertyId with your ID, but put it in quotation marks, since it's a string.
commit.
Then I went to my other document and installed the featurescript from my working demo clone and it's not working in the new doc
So I went to the clone of the stock size demo, where it's working. I created a derived parts studio from my other project (a simple box with edging) added auto layout and stock size, then created an assembly from that parts studio and edited the BOM table to show title3, and stock size is not working there (same doc, just another tab, this time working with derived parts)
https://cad.onshape.com/documents/f4a4130ff2031c1446b05699/w/569342730494bbce0c5f3964/e/8d0c400648004191d71c8ed6
1. a simple box doc (link in the first post where I said it wasn't working)
2. the clone of the stock size demo where I added a derived part studio from the doc above (but does work on the demo tab), link a couple posts up
Who says you can't multi-task playing video games and troubleshoot documents?
My god this tool is fantastic! Totally solves the problem we've been knocking our head against for a couple weeks.
It looks like your tool is built to do that but using the old beam feature but not yet the new frame tool.
I imported in what I think is the right library to be able to use the data from the frame tool but couldn't figure out where your code was calling info from the old beam tool.
Sorry to impose on your kindness, I'm super new to onshape and even newer to trying to figure out featurescripts.
I'm not sure how he did what he did either
Actually, I don't think I ended up completing it to work with Neil's feature. The import is there, but there is no references to it.
@MBartlett21
I was able to get this fantastic feature script running, but I might be missing something. How do I get it to recognize threaded rod, structural shapes, Unistrut ect...? I only see options for Auto, Bar, Round, Pipe, Sheet Metal, Custom.
Then you have to enter a string to represent the profile size, then the feature just appends the length.
So for unistrut it would be
Custom
"P1000PG"
Then the output will be
P1000PG x 120"
Or for a 1-1/2" x 2" x 1/8" angle iron
"1-1/2\" x 2\" x 1/8\""
Will output
1-1/2" x 2" x 1/8" x 120"
You can also put a variable in the custom as long as it still formats like above.
So measure the profile and set them as variables and do
Custom
D1~"\" x "~D2~" \" x "~D3~"\" w/t"
Output example
3" x 3" x .125" w/t x 120"
Thanks!
