Using a closed loop sketch as path for opSweep
 mortezaPourmohamadi
                    Member Posts: 9 ✭
mortezaPourmohamadi
                    Member Posts: 9 ✭
                    Hi,
I'm trying to use a sketch inside FS as a path for the opSweep function.
It works fine when the sketch contains a few connected lines, but it throws an error as soon as it becomes a closed-loop (e.g. a rectangular path).
Any idea how it can be resolved?
@opSweep: SWEEP_PATH_FAILED
onshape/std/geomOperations.fs (const opSweep)
onshape/std/feature.fs (defineFeature)
Case Carcass (const plyBody)
        var path1 = newSketch(context, id + "path1", {
                "sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE)
        skRectangle(path1, "rectangle1", {
                    "firstCorner" : vector(0, 0) * inch,
                    "secondCorner" : vector(10, 10) * inch
        // Create sketch entities here
        skSolve(path1);
        var profile1 = newSketch(context, id + "profile1", {
                "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
        skCircle(profile1, "circle1", {
                    "center" : vector(0, 0) * inch,
                    "radius" : 0.5 * inch
        skSolve(profile1);
        opSweep(context, id + "sweep1", { // @opSweep: SWEEP_SELECT_PATH
                    "bodytype" : ToolBodyType.SOLID,
                    "operationType" : NewBodyOperationType.NEW,
                    "profiles" : qCreatedBy(id + "profile1", EntityType.FACE),
                    "path" : qCreatedBy(id + "path1", EntityType.EDGE)
and the error message:
             Jacob_Corder
                            Member Posts: 139 PRO
                    @mortezaPourmohamadi Jacob_Corder
 Did you try Kontstantins solution? When sketches are solved, the entites become wire bodies. It is also true that multiple edges are created as Konstantin stated above.
 for the profile you could use
 sketchEntityQuery(id+"profile1", EntityType.EDGE, "circle1");
 or
 qAdjacent(qCreatedBy(id+"profile1",EntityType.FACE),AdjacencyType.EDGE,EntityType.EDGE)
 for the path if it is closed, qAdjacent(qCreatedBy(id+"path1",EntityType.FACE),AdjacencyType.EDGE,EntityType.EDGE)
 or
 sketchEntityQuery(id+"path1", EntityType.EDGE, "rectangle1");
 2
This didn't solve the issue, though. There is no BODY in the "path1" sketch, so the resulting WIRE and EDGE list would be empty.
or
or
This worked beautifully!
