Using a closed loop sketch as path for opSweep
Hi,
I'm trying to use a sketch inside FS as a path for the opSweep function.
It works fine when the sketch contains a few connected lines, but it throws an error as soon as it becomes a closed-loop (e.g. a rectangular path).
Any idea how it can be resolved?
        var path1 = newSketch(context, id + "path1", {
                "sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE)
        skRectangle(path1, "rectangle1", {
                    "firstCorner" : vector(0, 0) * inch,
                    "secondCorner" : vector(10, 10) * inch
        // Create sketch entities here
        skSolve(path1);
        var profile1 = newSketch(context, id + "profile1", {
                "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
        skCircle(profile1, "circle1", {
                    "center" : vector(0, 0) * inch,
                    "radius" : 0.5 * inch
        skSolve(profile1);
        opSweep(context, id + "sweep1", { // @opSweep: SWEEP_SELECT_PATH
                    "bodytype" : ToolBodyType.SOLID,
                    "operationType" : NewBodyOperationType.NEW,
                    "profiles" : qCreatedBy(id + "profile1", EntityType.FACE),
                    "path" : qCreatedBy(id + "path1", EntityType.EDGE)
and the error message:
@opSweep: SWEEP_PATH_FAILED
onshape/std/geomOperations.fs (const opSweep)
onshape/std/feature.fs (defineFeature)
Case Carcass (const plyBody)
  • Jacob_Corder
    Jacob_Corder Member Posts: 141 PRO
    @mortezaPourmohamadi
    Did you try Kontstantins solution? When sketches are solved, the entites become wire bodies. It is also true that multiple edges are created as Konstantin stated above.
    for the profile you could use
    sketchEntityQuery(id+"profile1", EntityType.EDGE, "circle1");
    or
    qAdjacent(qCreatedBy(id+"profile1",EntityType.FACE),AdjacencyType.EDGE,EntityType.EDGE)
    for the path if it is closed, qAdjacent(qCreatedBy(id+"path1",EntityType.FACE),AdjacencyType.EDGE,EntityType.EDGE)
    or
    sketchEntityQuery(id+"path1", EntityType.EDGE, "rectangle1");
  • konstantin_shiriazdanov
    I think it is because closed sketch creates multiple coinciding edges. Try this:
    "path" : qCreatedBy(id + "path1", EntityType.BODY)-> qBodyType(BodyType.WIRE)->qOwnedByBody(EntityType.EDGE)
  • mortezaPourmohamadi
    mortezaPourmohamadi Member Posts: 9 ✭
    Thanks @konstantin_shiriazdanov
    This didn't solve the issue, though. There is no BODY in the "path1" sketch, so the resulting WIRE and EDGE list would be empty.
  • Jacob_Corder
    or
    or
    Thanks @Jacob_Corder
    This worked beautifully!  :)
