Width mate
kevin_shaw
Member Posts: 1 ✭✭
In solidworks, I commonly use a Width mate to place a rectangular part equidistant between two faces. I typically need this for fixtures that hold a PCB (Printed Circuit Board) and I want the board centered between the two interior faces of the fixture. Is there something similar in OnShape. I am exploring OnShape now. I have looked at the Pin Slot mate, but it's just too specific for just one task.
1
1. I have two parts that I want to center one inside of the other in my assembly. Because it is a rectangular hole, there is no implicit way to get the center of it.
2. I went to my assembly and inserted the grey part. The first thing I did was start a mate connector on the middle of the edge in the direction I wanted.
3. Change the type from 'On entity' to 'Between entities'. For the entity to be between, select the opposite face. This will put the mate connector, aligned the way it was before, between the edge and the face. This now gives me a point that is in the middle of the two faces.
I can't do an example right now, but just create an assembly with 3 parts and try to mate one equidistant between the other two, regardless of the distance between the two changes.
I'll model up an example later on tonight if needed.
Like this ?
https://cad.onshape.com/documents/d29ff8e74a0f49809e533f48/w/48fedb2064cc4f30a27ee6e8/e/c46b2fdb9683db1db3177334
https://cad.onshape.com/documents/63edd3009dcfb0269fbaa894/w/cd6411299a5477651df1cc97/e/93ac2ff9499805d08a9512b9
In this example I mated the yellow block as I would like it. But the pin slot mate only works because I added the blue part underneath. The blue part also won't work if the walls need to be moved, unless it is defined in context to the assembly.
If I had wanted to center between the walls that would be a nice mate to be able to add.
Another way might be to allow defining an assembly mate connector. Then I could make a mate connector that is in the center of the two walls, and use a pin mate.
Another nice thing would be to be able to lock rotation within the one mate. Either as part of the pin slot mate, or if there were a new mate for width.
Here is the assy
https://cad.onshape.com/documents/c626f606201f02555c041717/w/c2fe71c06476213040360097/e/a04fb84b13eaf7cddc410110
https://cad.onshape.com/documents/92972a0a94f295ddcf05858c/w/7eeddd97d49f27c00840448d/e/a5c7d7d0f201bbb6a9bec497
I used two planar mates so the middle bit can move around up/down and sideways but you could make one of them a slider if you wanted them to stay aligned...
https://cad.onshape.com/documents/83a755253b5234cbf13ab537/w/61109c6b7dba48adaf5f9a77/e/c8a1bb398efd9186045c5af9?renderMode=0&uiState=61f044894799ad2097f82777
I’m headed down to the basement to get the weed blower to blow the cobwebs out of my skull.
The relation let me do what I was trying to figure out yesterday
To be able to move the outside parts anywhere within a sphere
I would like to figure out how to not use as many mate features
I’ll go get a cup of coffee maybe that’ll help
Moving along a sphere is a bit different from the original topic which was to replicate the Solidworks "Width" functionality which I think my earlier example achieves with two mates and a linear relation (not ideal but not a horrible workaround and doesn't need any "dummy" parts).
Looks like you can achieve something similar to what you are doing with 2 parallel mates (you can apply limit to rotation to keep them aligned) and 3 separate relations to link the x, y and z (and no dummy/helper parts):
https://cad.onshape.com/documents/83a755253b5234cbf13ab537/w/61109c6b7dba48adaf5f9a77/e/e261f52ba22643f6f6c16d46?renderMode=0&uiState=61f0af9cac0dfc508ff9e59f
That’s excellent
Do me a favor and unlock that thing so I can copy it. I wanna take a look at that
Here you go, this should be public now instead of just a shared link: https://cad.onshape.com/documents/47c6c3f8282244773d012ab6/w/45c05cff81617055c12ed2f3/e/35595c8a9c42ad7502f40f26?renderMode=0&uiState=61f1867c27b84159870a69a5
In other words, there’s no way to do what you did by using an iPhone. At least not anyway I could figure out, other than using dummy parts like I did above
So I had to fire up my MacBook Pro to get your combination of mate features to work
I definitely prefer your more lean approach
Thanks for that example Eric
That's interesting about the limitation on Mobile.
It seems to that picking the degree of freedom is a key part of creating a "mate relation" so I wonder if it's a bug (might as well disable mate relations altogether on mobile if you can't set them up properly...), you might want to fil a bug report...
