Create joint with only one pin
ZakZak Member Posts: 6
Hi every one,
I'm designing a lamp as you can check on the following documment :
https://cad.onshape.com/documents/7bf75b96dc1837fe8ac50359/w/1ae12706b3cfe0dcf0960a6d/e/084cc1d6c7d60a8b8912e586
I want to create joints between all the pieces of my working in a way that I'll be able to regroupe them once they are cutted.
So I need a joint with only one pin open on one side (see pictures below)
I'm using Laser Joint feature, but I'm not able to configure it that way. Could you please advice ?
what Laser joint is generating :
what I'm looking for :
