spiral parts
jon_gladdersjon_gladders Member Posts: 4 EDU
Hi, I am trying to create a spiral part using the loft feature but for some reason the last loft section doesn't carry on but changes direction.  I can produce it using surfaces but that will affect shelling, etc:
Is there any way that I can control the direction of the loft?
Thanks,
Jon
  • MichaelPascoeMichaelPascoe Member Posts: 2,846 PRO
    edited March 2022 Answer ✓
    Yes, this can be done with the "Match connections" option.
    There are a few tricks to it:
    Once you match one set of connections, minimize that set of connections in order to start another set of connections.
    For more tips and tricks, check out the Onshape Learning Pathways. They are fantastic.
    RENDERCAD
    RENDERCAD
  • jon_gladdersjon_gladders Member Posts: 4 EDU
    Great, thanks for your swift response.
