Creating holes that within a specified distance
brennan_natoli
Member Posts: 15 EDU
How can I use the linear pattern tool to create holes that are equal distance apart within a specified distance?
Fusion is great becuase it allows you to set the diameter of the hole, number of holes, and set the distance. From there it will create equally spaced holes within that specified distance.
Is this possible in Onshape?https://cad.onshape.com/documents/3e561bcbec745d87f86c88b5/w/8b7c173e0a59da9b0661d382/e/fe3275b286cfbdb82957412a?renderMode=0&uiState=623cb65365fb366a26fd66dc
I am trying to create this grid pattern.
Optionsshawn_crocker Member, OS Professional Posts: 814 PRO@brennan_natoli
I've been using this feature and have found it very successful for accomplishing what you seem to be doing. https://cad.onshape.com/documents/ba244d5fd9c41b039f564f13/v/7bc5e9ce1d20fe946e46528d/e/f5fe9a6db31e40fcaae05f53. Thanks @MBartlett21.
I have also been using this. https://cad.onshape.com/documents/25c5ccb6a4d02f0be468071d/v/eb4faab0fc6209aee5674b81/e/6d5ae391574d2083c40e19a0.
1
https://cad.onshape.com/help/Content/linearpattern.htm?Highlight=Linear pattern
Website: ovyl.io
@dirk_van_der_vaart the help file does not explain how to do the specific task of creating equal amount of holes within a set distance.
thank you!
I can math the correct result but way back when I first took CAD class, my instructor told us that if we have to do math to get the result we want then we are not doing it right because design intent is lost.
Linear pattern up to seems pretty cool though! I'll have to try it out! (and fill pattern as well)
I finally finished my feature that should do exactly what you're looking for here. Check it out! https://cad.onshape.com/documents/1196579d97167d7a348652a9/v/1c9b35be187e7992fe9815d7/e/3e9783cad47053c2abb99ce0
Website: ovyl.io
For some reason I can't access this file.
Website: ovyl.io
There we go! Nice work!
