Simple Rotate
allen_keshishian
Member Posts: 9 ✭
Hello All,
This is a very simple question. If I have drawn a shape and I want to copy and paste said shape somewhere else but rotated 37 degrees. How do I go about doing this. I cant seem to find the rotate button.
Thank you
Thank you
If you meant a solid body, when you said "Shape", then @shanshan has answered perfectly.
If you meant a sketch (2D) "shape", then we need to show you a different method.
It's still confusing, because you almost seem to be going for the 'shortest post' prize
(I didn't even know there was one ... and it probably shows ...)
You need to throw us a bit of meat here, mate, not just a gnawed bone!
Is it just the "shape" that is 2D, or (in addition) are you trying to rotate it on a 2D plane, (ie about an axis normal to that plane)
or alternatively: are you trying to rotate it about an axis at some other angle (which means creating a new destination plane, and copying your sketch across to it) ? ? ?
Dimension tool activates angle when you select two instances which are not paraller, you might need some construction line and additional constraints but should be pretty straight forward.. Please let me know if you need any further explanation.
+1 for an upgrade!
The group would include a sketch point to specify the desired rotation centre. Applying a "fix" constraint (or a pair of dimensions) to this point would mean the group would rotate about it.
Had forgotten to group my parts after selection!
I was needing to do this operation yesterday when trying to copy a sketch from one plane to another (planes at different angles to each other) and although I could paste the copied sketch, the orientation was completely wrong on the new plane and it appeared that the copy 'carried over' constraints from the first plane, making it impossible to rotate without distortion. I gave up in the end and redrew the sketch on the new plane from scratch.
Then when you paste the sketch in a new location, you should be able to simply delete that single constraint and recreate it in an appropriate way for the new situation.
