Problem with Boolean function
I am very new to Onshape, so very unfamiliar with the boolean function. I am working on a project for a pipe structure, and the criteria is to only work on surfaces. I am trying to merge the two pipe surfaces, but Onshape followed with the prompt " Boolean resulted in no geometry change. The parts either do not intersect or are totally contained." Would be very helpful if anyone knows how it is done, or could explain why this is a problem?
Pipe Project
https://cad.onshape.com/documents/eb9e5e7ab95e3c9cbb2f05d7/w/a8cb5905d1595fc5a0c53080/e/d8a6db664cdd3fbcea92365c?renderMode=0&uiState=62d899cf6b3ece5008aff81f
