BOM columns: Possible to add XYZ-Dimension of a part?
martin_kopplow
Member Posts: 281 ✭✭✭
When preparing production, I usually get asked how much material will approximately be needed. In my old CAD system, I had the opportunity to add a column to the BOM to display the XYZ-Dimensions of every part which, even if not 100% accurate for irregularily shaped parts, helped a lot with the estimation. The shop could easily check their stock against the BOM.
Is it possible in Onshape BOM, to do the same? I only see a very limited choice in the "Add column ..." menu.
Best,
Martin
Here is a pretty robust bounding box feature you can add to your toolbar: Aligned bounding box
If you need to see these in the BOM, you can use something like this to set a property using variables: Set Property Take the variables created by the bounding box and assign them to a property like @edward_petrillo mentioned. These properties can be viewed in the BOM.
Also, if you just want to see the xyz of your part, you can use the bounding box feature, then open the variable table on the right panel:
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
