Want instances in fill pattern to be close together.
richard_hill906
Member Posts: 1 PRO
The fill pattern is such a useful tool. Thank you to whoever created it. However I am running into a problem. I create a cylinder .9 inch in diameter and .125 in length. I want my instance spacing to be 1 inch. However the smallest I can go with the fill pattern tool is 1.279. If I go any smaller I get the message "pattern instances too close together, try a larger spacing". I believe the feature script is determining the min instance spacing based on a diagonal length of a boundary box instead of the diameter of my cylinder. I am confident there is a way to change this but I am not good enough with the code to know what to change. Any help would be greatly appreciated.
You are correct - the spacing is determined by the bounding box of the feature. Please DM me with an example and I will see if I can fix it.Senior Director, Technical Services, EMEA0
@richard_hill906I have no idea of how advanced you are with the program. But I thought I’d just throw this out there
If you’re at all interested in patterning AROUND the cylinder, circular pattern is nice to keep in mind because it EVENLY distributes without having to do any kind of calculations
@NeilCooke I'm in the same boat, needing to do a square fill pattern with instances more closely spaced than the bounding box allows (for example, Ø0.213" circles in rows and columns spaced 0.296" apart). Shall I send you a PM? Thanks!0
Yes, with an example of what you are trying to do.cary_bettenhausen said:@NeilCooke I'm in the same boat, needing to do a square fill pattern with instances more closely spaced than the bounding box allows (for example, Ø0.213" circles in rows and columns spaced 0.296" apart). Shall I send you a PM? Thanks!Senior Director, Technical Services, EMEA0 -
cary_bettenhausen said:fill pattern with instances more closely spaced than the bounding box allows (for example, Ø0.213" circles in rows and columns spaced 0.296" apart)A FILL that is patterned
Look at the diameter of the circles
Look at the spacing
https://cad.onshape.com/documents/34f4f6f29588881a0f69b1a9/w/641072241ce9a60f8c4bb2e4/e/6810472b390b3ac1e5aa985b
To be clear, I'm asking about the Fill Pattern custom feature.steve_shubin said:cary_bettenhausen said:fill pattern with instances more closely spaced than the bounding box allows (for example, Ø0.213" circles in rows and columns spaced 0.296" apart)A FILL that is patterned
Look at the spacing
https://cad.onshape.com/documents/34f4f6f29588881a0f69b1a9/w/641072241ce9a60f8c4bb2e4/e/6810472b390b3ac1e5aa985b0 -
cary_bettenhausen said:To be clear, I'm asking about the Fill Pattern custom feature.
Take a look at both part studios in the below document - both done with FILL PATTERN FS
As far as close spacing - look at the FILLED CIRCLES part studio
For the exact dimensions you quoted - look at the HOLES part studio
https://cad.onshape.com/documents/2f45c12d3f3d09b64819aaf9/w/4041eef6a01f574e913b40d2/e/80e0008d720367088f8a0764
1 -
@steve_shubin Thank you, I see now the difference is creating a Fill Pattern of a Hole feature vs. creating an FP of a hole by sketching a circle and extruding it. I just need more time wrapping my brain around the Onshore way and shedding the old S****W**** habits!
This is a different Fill Pattern custom feature.0 -
cary_bettenhausen said:@steve_shubin Thank you, I see now the difference is creating a Fill Pattern of a Hole feature vs. creating an FP of a hole by sketching a circle and extruding it. I just need more time wrapping my brain around the Onshore way and shedding the old S****W**** habits!
I would guess that because of it being a different Fill Pattern FS, that is why you are having the problem
With the Fill Pattern FS I am using, it works using either the Hole FS or by extruding a circle made in a sketch
In the GIF below
I duplicated the part studio called Holes
In the features tree, I deleted the Hole’s featurescript
Edited the sketch in that I added a circle
Extruded that circle with it set to remove
In the feature tree, moved the extrude up to just below the sketch
Modified the fill pattern in that I deleted the missing face of the deleted hole
But in its place, I added the face of the hole that was made by extruding a circle
