Want instances in fill pattern to be close together.
The fill pattern is such a useful tool. Thank you to whoever created it. However I am running into a problem. I create a cylinder .9 inch in diameter and .125 in length. I want my instance spacing to be 1 inch. However the smallest I can go with the fill pattern tool is 1.279. If I go any smaller I get the message "pattern instances too close together, try a larger spacing". I believe the feature script is determining the min instance spacing based on a diagonal length of a boundary box instead of the diameter of my cylinder. I am confident there is a way to change this but I am not good enough with the code to know what to change. Any help would be greatly appreciated.
    You are correct - the spacing is determined by the bounding box of the feature. Please DM me with an example and I will see if I can fix it.
  • steve_shubin
    steve_shubin Member Posts: 1,118 ✭✭✭✭
    edited July 2022
    @richard_hill906
    I have no idea of how advanced you are with the program. But I thought I’d just throw this out there
    If you’re at all interested in patterning AROUND the cylinder, circular pattern is nice to keep in mind because it EVENLY distributes without having to do any kind of calculations
  • Cary_Bettenhausen
    Cary_Bettenhausen Member Posts: 51 PRO
    @NeilCooke I'm in the same boat, needing to do a square fill pattern with instances more closely spaced than the bounding box allows (for example, Ø0.213" circles in rows and columns spaced 0.296" apart). Shall I send you a PM? Thanks!
    Yes, with an example of what you are trying to do.
  • steve_shubin
    edited January 2023
    A FILL that is patterned
    Look at the diameter of the circles
    Look at the spacing
    https://cad.onshape.com/documents/34f4f6f29588881a0f69b1a9/w/641072241ce9a60f8c4bb2e4/e/6810472b390b3ac1e5aa985b
  • Cary_Bettenhausen
    Look at the spacing
    To be clear, I'm asking about the Fill Pattern custom feature.
  • steve_shubin
    edited January 2023
    Take a look at both part studios in the below document - both done with FILL PATTERN FS
    As far as close spacing - look at the FILLED CIRCLES part studio
    For the exact dimensions you quoted - look at the HOLES part studio
    https://cad.onshape.com/documents/2f45c12d3f3d09b64819aaf9/w/4041eef6a01f574e913b40d2/e/80e0008d720367088f8a0764
  • Cary_Bettenhausen
    edited January 2023
    @steve_shubin Thank you, I see now the difference is creating a Fill Pattern of a Hole feature vs. creating an FP of a hole by sketching a circle and extruding it. I just need more time wrapping my brain around the Onshore way and shedding the old S****W**** habits!
    This is a different Fill Pattern custom feature.
  • steve_shubin
    edited January 2023
    I would guess that because of it being a different Fill Pattern FS, that is why you are having the problem
    With the Fill Pattern FS I am using, it works using either the Hole FS or by extruding a circle made in a sketch
    In the GIF below
    I duplicated the part studio called Holes
    In the features tree, I deleted the Hole’s featurescript
    Edited the sketch in that I added a circle
    Extruded that circle with it set to remove
    In the feature tree, moved the extrude up to just below the sketch
    Modified the fill pattern in that I deleted the missing face of the deleted hole
    But in its place, I added the face of the hole that was made by extruding a circle
