New Feature: Configurable Text Box
imants_smidchens
imants_smidchens Member Posts: 84 PRO
Ever wanted to create multi-line configured text? Now you can! Boasting a mediocre regeneration speed and a solid handful of inputs, the Text Box featurescript lets you do just that. Snag the feature here: https://cad.onshape.com/documents/013a3a2af7ff812f3502ef95/w/0076c51513cb240fd5048c18/e/f05c226759cac7af57f44b4d
Definitely let me know what improvements you would want to see!
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,944 PRO
    I needed something like this a while back. Thanks!
    RENDERCAD
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,099 image
    With built-in Rick Astley lyrics too. Nice.
  • Pardon my ignorance, but how does one use this?
  • MichaelPascoe
    edited October 2024
    @craig_sampsone8ee42942f35db588f0c78b0
    Here is how you can add it to your toolbar and use it:
    • First, sign in, and view the document from the link above.
    • Add the feature to your toolbar with the custom features button at the top middle of the screen.
    • Go to your own document, and use the feature. You can use the search bar in the top right of your document to find the feature easily (Text box)
    • The text box multi-lines are controlled by the width of the text box. There is an input for changing that.
    RENDERCAD
