Query for entities to boolean
ben_partouch
Member, csevp Posts: 162 PRO
Hi,
I'm trying to boolean subtract bodies created with oppattern inside a for loop. Not sure what I should do...
Thank you!
doc:
https://cad.onshape.com/documents/ef3ba98102efc6b4e4c71194/w/50cf1b58a05a4b7c535589fd/e/8c530af3038d5e69dbf7c755
Thank you!
doc:
for (var i = -1; i < definition.numberOfHoles - 1; i += 1)
const computedTransforms1 = transform((vector(0 * centimeter, 0 * centimeter, definition.holeSpacing)) * (i + 1));
opPattern(context, id + ("patternB" ~ i), {
"entities" : qCreatedBy(id + "extrude1", EntityType.FACE),
"transforms" : [computedTransforms1],
"instanceNames" : ["Holes"]
// opBoolean(context, id + "boolean2", {
// "tools" : qCreatedBy(id + ("patternB" ~ i), EntityType.BODY),
// "targets" : definition.panels,
// "operationType" : BooleanOperationType.SUBTRACTION
Change your pattern to EntityType.BODY not EntityType.FACE
opPattern(context, id + ("patternB" ~ i), {"entities" : qCreatedBy(id + "extrude1", EntityType.BODY),"transforms" : [computedTransforms1],"instanceNames" : ["Holes"]});1 -
Thanks @Jacob_Corder.
Looks like it can stay FACE but my id was wrong. Now- opBoolean(context, id + ("boolean2" ~ i).
Seems to work:)0 -
For speed, build an array of transforms and names in the for loop then do opPattern and opBoolean once. Our servers will thank you.Senior Director, Technical Services, EMEA0
Thanks @NeilCooke.
I would love to take you advice but my capabilities in FS are so amature and limited that I have no idea how to do what you suggested LOL.
My code is so inefficient. Would love to learn how to get better at this!
He means something like this. I've not tested this code, but the idea is there if not the functionality.
//for loop for drilled holes var computedTransforms1 = []; // make an empty array to later store transforms var instanceNames = []; // make an empty array to later store instance names<br> for (var i = -1; i < definition.numberOfHoles - 1; i += 1) { const computedTransform = transform((vector(0 * centimeter, 0 * centimeter, definition.holeSpacing)) * (i + 1)); computedTransforms1 = append(computedTransforms1, computedTransform); // add the new transform to the array instanceNames = append(instanceNames, "hole"~toString(i)); // add the new instance name to the array<br> } // no more need to add + i to the Id's here since you only call the functions once. opPattern(context, id + "patternB", { "entities" : qCreatedBy(id + "extrude1", EntityType.FACE), "transforms" : computedTransforms1, "instanceNames" : ["Holes"] }); opBoolean(context, id + "boolean2", { "tools" : qCreatedBy(id + "patternB", EntityType.BODY), "targets" : definition.panels, "operationType" : BooleanOperationType.SUBTRACTION });
1 -
I'll give it a shot! Thanks guys.
Couldn't make it to work.
Thanks for looking into it:)0 -
Which bit is failing?ben_partouch said:Couldn't make it to work.
Thanks for looking into it:)Senior Director, Technical Services, EMEA0 -
opPattern(context, id + "patternB", { "entities" : qCreatedBy(id + "extrude1", EntityType.BODY), "transforms" : computedTransforms1, "instanceNames" : instanceNames });
Oops. That's on me. Glad you got it working.ben_partouch said:
