MKCad app not working -- it just flashes
tim_paterson
tim_paterson Member Posts: 7 EDU
I subscribed to the MKCad LIbrary app, and it came up in the side panel and asked for authorization.  After that, all that it does is flash between gray and white.  I tried unsubscribe and subscribing again, and it didn't help.  I logged in on a different computer, and still got the same result.  I'm running Chrome on Windows.
  • alnis_ptc
    alnis_ptc Member Posts: 6 ✭✭
    @tim_paterson could you please try again? It works for me now.
    There was an issue in Onshape that caused many right panel app store extensions fail to load properly, and a fix has been deployed. Please let me know if it's still not working for you. Thanks!
    Senior Innovation Engineer at PTC OCTO | Get in touch: asmidchens@ptc.com
  • tim_paterson
    There was no change when using Chrome. I did try using Microsoft Edge (which I've never used before), and it worked.
    So it works in Edge but not in Chrome.
  • tim_paterson
    This problem is caused by having third-party cookies blocked. It was instantly solved by changing this setting under Chrome's Privacy and security settings.
