MKCad app not working -- it just flashes
tim_paterson
Member Posts: 7 EDU
I subscribed to the MKCad LIbrary app, and it came up in the side panel and asked for authorization. After that, all that it does is flash between gray and white. I tried unsubscribe and subscribing again, and it didn't help. I logged in on a different computer, and still got the same result. I'm running Chrome on Windows.
@tim_paterson could you please try again? It works for me now.
There was an issue in Onshape that caused many right panel app store extensions fail to load properly, and a fix has been deployed. Please let me know if it's still not working for you. Thanks!Senior Innovation Engineer at PTC OCTO | Get in touch: asmidchens@ptc.com
@alnis is my personal account. @alnis_ptc is my official PTC account.0 -
There was no change when using Chrome. I did try using Microsoft Edge (which I've never used before), and it worked.
So it works in Edge but not in Chrome.0 -
This problem is caused by having third-party cookies blocked. It was instantly solved by changing this setting under Chrome's Privacy and security settings.0
