Sketch Linear Pattern: Can I use variable for the number of instance?
ray_yip548
Member Posts: 5 ✭
Is it possible to obtain a reference to the highlighted dimension in subsequent steps, regardless of how many instances there are?
This feature is now supported, see release note here:
https://forum.onshape.com/discussion/210830
Senior Director, Technical Services, EMEA0
This is bothersome especially for sketching on a flat pattern. Using a feature/face pattern on the flat pattern is not possible. What I sometimes do, is pattern out way more sketch entities then I need. Then I use a config list and configure which sketch faces are selected in a feature. You get a similar result but not infinite.0
