Thickness Analysis (New Custom Feature!)
MichaelPascoe
Member Posts: 1,732 PRO
https://cad.onshape.com/documents/thicknessAnalysisWith this custom feature, you can easily analyze the thickness of multiple faces. Special thanks to @Jacob_Corder for some performance tips.
This feature is sponsored by CADSharp.com. If your daily modeling is repetitive, consider automating your process with CADSharp to save time. CADSharp specializes in automation by utilizing custom features and API.
Set limits and report errors if they are exceeded:
Tips:- Relevant values are stored as variables in the Variable table on the right side of your screen.
- For large selections, uncheck "Analyze thickness" until you have created your selections.
Import functions to use with your own custom features:
Use these functions in your own custom features by placing the following import at the top of you code.- thicknessAnalysisPascoe() //Analyzes the thickness between two or more surfaces.
- faceGridPascoe() //Splits the selected face into a grid.
- colorGradientPascoe() //Returns a color based on a fractional input.
import(path : "55e98155dca4ba4e8049a18d/264916e1790d6b19b353dda6/c1fcec00ad4e3a44bd7f5a8c", version : "364ad9f0f694974f4028c05c");
How to add a custom feature to your toolbar:
Click this link then follow the steps in the gif below: https://cad.onshape.com/documents/thicknessAnalysisLearn more about the Gospel of Christ ( Here )
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
Twitter: @BryanLAGdesign
Nice tool. I like it
Thanks @steve_shubin, glad its working! Though I can't take credit for the math behind the colors. The original three color gradient function is derived from luiscla27 at stackoverflow.com/questions/30143082.
Website: ovyl.io
Update!
Ok, so you didn’t come up with the math for the coloring. But you did the other part. And without your effort, I would not have the thickness analysis tool
https://bids.github.io/colormap/
@S1mon this is a good point. I have implemented something similar in the latest update:
Update!
Axel Kollmenter
This was designed for a few faces at a time, not complex parts (depending on your definition of complex). Though this should work for portions of the complex parts.
Do you have an example part you could share?
Update!
- Improved performance - 2x faster!
- Fixed bug where you could not select nodes if multiple faces were analyzed.
- Changed icon.
- Added CADSharp.com URL. Stay tuned, we have some neat things coming soon related to custom features
https://cad.onshape.com/documents/55e98155dca4ba4e8049a18d/w/dbf02fb86aafef13f08be126/e/67...Learn more about the Gospel of Christ ( Here )
