aDA
marion_caulet
Member Posts: 3 ✭
hello,
I would like my bending radius to be adapted on some area of my wire because some part of my wire are moving with a bending of 7.5 and some are fixed with a bending of 4.
If I put the variable bending radius of the mobile one on the fixed part the routing is in default (need more space most of the time) Vs if I put the fix radius I cannot contrôle the mobile radius one .
Do you have an idea of how it could be achieved?
Thanks for looking up to my question,
best regards,
best regards,
Currently this can only be done manually. While editing the wire, right-click on the screen and show curvature with minimum bend radius. You can then edit the wire to get the bend radius you need.Senior Director, Technical Services, EMEA0
Any future requests please post here: https://forum.onshape.com/discussion/18756/custom-feature-cable-wire-routingSenior Director, Technical Services, EMEA0
