Measurement variables on in variable tables (please hear me out)
jules_smith
Member Posts: 24 EDU
If you could somehow put measurement variables in variable studios, you could then use them to drive mate limits -meaning you could make an entire moving assembly, complete with limits that is all parametrically controlled in a part studio. You could also drive parameters in other part studios if you want to design parts in separate studios and make them all linked together without deriving them. The first use-case is probably a lot more useful I just often find myself annoyed that I edit a sketch a little bit in post and find myself having to change things in the assembly. I know there are ways to simplify this but it would be cool if there was a way to automate it. (if there is one let me know)
Here is an improvement request you can vote on if you like: Driven Variables in Variable Studio - Improvement Request
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
