Cannot modify a part that has mesh as one surface
matti_suuronen
Member Posts: 19 ✭✭
I have a 3d scanned mesh surface, that I imported as .obj, and I have created a solid that fits that surface, or rather that one part of the solid is that surface. It seems I cannot freely remove/add to that solid by extruding. I might understand this if the resulting geometry would somehow touch the mesh surface, but I cannot even create a small pocket on one of the flat non-mesh surfaces, no matter how shallow the pocket is, or how far from the mesh surface. And with some other similar one-side-is-a-mesh solids this works just fine. What might be causing this? Can I work around it somehow?
Something about the preceding Split and/or Lip operations leaves you with a bad edge on that top face. The parasolid kernel is not able to make further operations to a face bordered by a bad edge, so your hole operation fails. I would recommend not doing the Lip and Split operations and instead do one extrude to remove the top body:
This results in the same geometry but without the bad edge. I was then able to make the failed extruded hole operation succeed without modification.0
@matti_suuronen
It's a bit hard to say without a link to your document to see a few more details.
Are you sure that you're not working with all surfaces?0 -
I'd think these are not surfaces, as the part results from a split of a body that originates from an "enclose". Here is the link https://cad.onshape.com/documents/542c31bb37c34cd27d8bfae0/v/9b6a17dd435e3f31e8e0bf73/e/7c2c8434f546ad1e760de18c0
@matti_suuronen
You have something weird going on right under the surface that is causing non-manifold geometry when you try to extrude.
This results in the same geometry but without the bad edge. I was then able to make the failed extruded hole operation succeed without modification.0 -
@matti_suuronen
Sorry it looks like I was only partially right, @jnewth_onshape posted a much more complete and helpful answer.0 -
I need both the top and the bottom parts, so I needed to copy the body in place, but now it works, thanks!
I've used splits quite a lot with meshes, as it seems like extrudes do not always work with them, but it is good to know that it sometimes matters how you arrive to a certain geometry, and extrudes have their place. Of course it would be nice to know _why_ the spilt (or something) corrupted the edge..0 -
Mesh support is a fairly new feature in Onshape, and a fairly new one for the Parasolid kernel (as I understand it). I would also like to figure out why that edge is corrupted. Please file a bug using our built-in reporting tool:matti_suuronen said:I need both the top and the bottom parts, so I needed to copy the body in place, but now it works, thanks!
It's enormously helpful to the dev team because then we can share the issue with Parasolid and investigate the root cause ourselves.1 -
Great, I will do that, thanks for pointing out the bug reporting possibility👍1
