ho do I connect these 5 parts to a surface
jenx
Member Posts: 4 ✭
I am trying to connect these parts to what it calls a surface. When I 3d printed this the parts just snap off ad they arent joined.
How to I connect them?
https://cad.onshape.com/documents/12c89ecba01c6cb64bcb2f3b/w/e84e887539f7e362846ea024/e/1eaf2d35cdd00cabc6888881?renderMode=0&uiState=658c5dd9dc5c6f79e0a27709
Hello. Onshape is a solids and surfaces modeler. Your import is a mesh and is not usable for further modeling.Two options I know of are to:Remodel the import in Onshape.Go back to your import source an see if a file format that Onshape can use is available.There are plenty of videos available online that demonstrate remodeling a mesh. - Scotty0
Yes remodelling is the best option here. I have managed to repair the original file so it is a "Part' which means you can use mixed modelling in Onshape
https://cad.onshape.com/documents/ded1c5089601d3b1101f1ab5/w/e574fd24a55d5c1ead705052/e/6d8ba7950eb84450c6f1b645
1 -
Thats Perfect. Thanks so much. I still couldnt work out how to do it myselfGWS50 said:Yes remodelling is the best option here. I have managed to repair the original file so it is a "Part' which means you can use mixed modelling in Onshape
https://cad.onshape.com/documents/ded1c5089601d3b1101f1ab5/w/e574fd24a55d5c1ead705052/e/6d8ba7950eb84450c6f1b6450 -
The STL file that you imported came in with faults with some surfaces and some parts. I used other software to repair the STL and then re-imported it1
