Design using a "Derived" version of a configurable model... ?
Not sure what to call this, hence the question mark in the discussion title.
I want to model something, configurable, based on another model which is also configurable, WITHOUT having to go through the process of instantiating first into an Assembly and then having to design "In Context".
The idea is as follows:
https://cad.onshape.com/documents/5a6712015fe591f0510283e5/v/a1e5ffce4ab71a0c4d726db9/e/ea2ea2576ad949677bdc5957
Following the aforementioned steps:
I am aware that I could simply measure the table's height and input this to a configuration variable for the legs, but I want to know it the above is possible.
Anyone?
- Create a configurable model in Part Studio 1.
- Import (?) this model into Part Studio 2.
- Create another configurable model, based on the geometry from PS 1.
- Instantiate first PS 1, then PS 2 into Part Studio 3. The geometry from PS 2 should fit any configuration instantiated from PS 1.
- Created a configurable tabletop. (Variable: Height)
- Imported/Derived this into a new PS.
- Created configurable table legs which extend up to the bottom surface of the table top. (Variable: Legwidth)
- Tried to instantiate both of these into a third PS.
Anyone?
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless
HWM-Water Ltd
