Face Pattern by selecting Features
sebastian_glanznersebastian_glanzner Member, Developers Posts: 474 PRO
As many of you already know "Face Patterns" are a lot faster than "Feature Patterns", especially when working in sheet metal.
The only thing that is annoying that you have to select each face to use this feature and when you change the features, you have to reselect the faces.
The blue box should state "Faces or Features to pattern":
I think it should be possibly to use "Face Pattern" and select the features in the browser tree.
Because if you select features, then all the faces are highlighted in orange already.
  • Don_Van_ZileDon_Van_Zile Member Posts: 195 PRO
    Face pattern is faster (*performance*) so anything provided to the user to promote selection of faces - sure. +1
    feature pattern without checking "apply per instance" checkbox already behaves as face pattern for all faces created by selected features
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 474 PRO
    Hey you are right! Haven't seen this button before  :smile:
    So does it still make sense to use a face pattern with selecting features?
    I just learned something new today too!  :)
    edited September 2018
    I have an IR to allow feature icon selection as a query parameter for all features with query fields. They might be jointed.
