steam engine
in General
does anyone know how i get a proper movement on crank and rod?
https://cad.onshape.com/documents/0855cece66b911502331ab6f/w/a90a0eaf43759a939712e47b/e/0d6519de0f67aa0bc7ee59db
Great looking model!
There was a mate conflict in the sub-assembly "vevstakar ass" where Revolute1 was failing. You appear to have recreated this mate with Revolute2, you you can suppress or delete Revolute1.
If you then add a Cylindrical mate between the crank and rod the mechanism you'll get the motion you want. I chose Cylindrical because the mate connectors only need to be aligned _along_ the axis, not coincident which Revolute would need.
Andy
But I ALSO fixed a bunch of screwy stuff in the main frame
https://cad.onshape.com/documents/487b52106bcc0a246cdd2296/w/3e9cabc42157186c4ea2504b/e/b93515836c952cf104e2e60c
maybe i gonna build this steamengine.
HWM-Water Ltd
