Am I being obtuse, or has the Measure tool been removed?
RChilcoat
Member Posts: 12 ✭
I'm sure I used it when I first started using OnShape. I can't find it anymore. The help files say it should be at the right end of the bottom of the screen, but there's nothing there. Is it only on certain screens? I want to measure some hole diameters on an assembly without going back and editing the sketches. Thanks.
The measurements should appear whenever you have entities selected in a Part Studio or an assembly.
Example:
Are you not seeing this text in the lower right corner?
5 -
Hi - The Measure tool appears automatically when you have something selected (that can be measured) in a Part Studio or Assembly. I hope this helps. Thanks for asking!
Diane
Diane Amadeo - QA Team5 -
Sometimes especially in Assemblies it can become slow and may take a long time to show up.5
Thanks everyone. The help files show a little icon that looks like a pair of dividers, and that was what I kept looking for. I didn't think to just select something on the assembly. Works great. Now back to work.
Example:
5 -
Diane
@RChilcoat
Please vote on this IR if you believe this would have prevented this
https://forum.onshape.com/discussion/10216/visual-aid-for-measure-calculation/p1?new=1
The help files should be updated to reflect this change. Measuring is now automatic and doesn't require selecting a tool. I got stuck searching for the none existing tool that is described in the help.0
