Drawing views are scaled differently....??
ari_pihlainenari_pihlainen Member Posts: 1
One or more drawing views are scaled differently from the sheet. Some dimensions translated from these drawing views may appear out of scale with any new dimensions created in target systems.
How to get rid of this message?
  • timandrewstimandrews Member, Moderator, Onshape Employees Posts: 18 image
    edited October 2018
    Hi Ari, thanks for raising this issue. This warning message is a known issue and we are in the process of removing it. You will see this message any time you export a drawing that contains views different than the sheet scale. Your exported drawings are still correct; we are just warning about the view scale when we shouldn't be.
