Rotate part around an axis of a different part, not aligned.
don_williams909
Member Posts: 147 PRO
I'm finding that Mate Connectors have some (large) limitations. I'm wanting to rotate a part in an assembly around the center of a hole in another part, which is offset in the XY direction, not in the Z direction.
Since the Revolute Mate doesn't work when offset in this manner, and a Slot Made doesn't work with a curved slot, there needs to be some other method for revolving a part, base on an axis of a hole, or something other than a Mate Connector.
Why don't you just add a Mate Connector in the part you want to rotate where its rotation axis should be?
When you use a mate connector on an arc, it will default to the centre.
Do you want the point you marked "Point of revolution" to go in the curved slot or what?
IR for AS/NZS 1100
