Is there a getAllVariables()? Specifically Configuration Variables.
leon_poot
Member, Developers Posts: 87 ✭✭✭
Is there a way of accessing a list (map) of all (configuration) variables in a Part Studio?
Perhaps a way of accessing the input of the build(config) function?
Basically a
Basically a
getAllVariables()is what I'm after, in the spirit of
getAttributes(...qEverything()...)
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless
There is currently no such function. The end user can, of course, explicitly set any quantity or isAnything input to #myConfigVariable. This is the preferred, non-magical way of using those values. If you'd like a magical way, please submit an improvement request with your use case
If you're just looking to find a single variable (or any of a small set of known ids) which may or may not be set, note that you can sayconst possibleValue = try silent(getVariable("possibleId"));This will benignly set possibleValue to undefined if the variable doesn't exist.
5
5 -
And here I was, hoping for a little Abracadabra... (fun fact: that term is, in written form, likely over 1700 years old).
Jokes aside it can't be impossible to make this magic happen since all the info is there, and is readable under "Show Code". I'll submit an IR.
As Arthur C. Clarke puts it so eloquently:"Any sufficiently advanced technology is indistinguishable from magic""A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless0
