Closed Contour Color
brian_sherrer33brian_sherrer33 Member Posts: 1 EDU
Any having an issue with the closed contour color appearing?  I have a few stations where this is happening in my classroom, but I'm not sure why a web-based app would save any setting changes if another student changed them.  There is no shading once the object is created, everything has a white fill.
  • philip_thomasphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
    @brian_sherrer596 - This is super hard to diagnose just based on a textural description. A screen shot would help.
    1) Is everyone using the same browser? Is this problem browser dependent? The officially supported platforms are; Chrome, Firefox, Safari, Edge, IOS and Android.
    2) I THINK you are referring to the region shading on a sketch. No shading usually means that the contour is not closed and therefore does not define a region. The easiest way to find the 'break', is to cut the sketch in half with a line - one half will shade, the other will not. Divide the un shaded region in half with another line and so on until you have isolated the two entities that do not touch
    I hope this helps :)
    Philip Thomas - Onshape
