Animation
john_brodowskijohn_brodowski Member Posts: 37
  • TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315 image
    Looking a the assembly it appears that the "Linear" and "Rack and Pinion" are already linked. You can see what I mean in the gif linked below:
    https://cl.ly/de17d47861d8
    Onshape, Inc.
  • john_brodowskijohn_brodowski Member Posts: 37
    I want entire assembly to be animated in unison. As it is now, it is disjointed. To accomplish what I want, the ROD has to be linked with the WHEEL GEAR,
    it is "hanging in the air" now.
    What Connectors should be used to do it?
    What you have shown is exactly what I have, not what I want.
    Thank you
    To connect the link and the wheel you would want to use a cylinder mate as this constrains all DOF except movement along the rotating axis as well as rotation around the axis.
    Onshape, Inc.
    Great !! It woks...I never used Cylindrical connector.
    Thank you again
