Enum used as a parameter type must be exported?
Aaron_Hoover
Member Posts: 35 EDU
I am trying to use the BoundingType enum in a Featurescript that I'm developing that includes an extrude. I keep getting the error "Enum used as a parameter type must be exported" when I try to use the BoundingType like so:
The BoundingType enum seems to be used without issue in the Featurescript mentioned in this post about extruding a profile. What am I missing?
annotation { "End Type" : "End Type" }
definition.endType is BoundingType; The BoundingType enum seems to be used without issue in the Featurescript mentioned in this post about extruding a profile. What am I missing?
Answering these types of questions is only really possible with a link to your document. I would guess the difference is the "export" keyword preceding the geometry.fs import in the other post is missing in your document -- so your code should read:
FeatureScript NNN;
Where NNN is the FeatureScript version you're using.
export import(path : "onshape/std/geometry.fs", version : "NNN.0");Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
FeatureScript NNN;
export import(path : "onshape/std/geometry.fs", version : "NNN.0");Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5 -
Yep. That did it. I didn't realize I needed to preceded the import with "export." Thank you.0
@Aaron_Hoover
I would suggest just exporting the enum you need.export import(path : "onshape/std/boundingtype.gen.fs", version : "937.0");
Some reasons can be found at https://forum.onshape.com/discussion/9583/multiple-declaration-warning0 -
I agree with Morgan -- adding the export to geometry.fs was the simplest solution, not the best one.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1
