Circular Pattern - Can't Select the Thing to Duplicate
Trying to make a ball chain sprocket. I'm trying to do a circular pattern of that hole you see up there and it won't let me select it. I thought I found the answer in the drop-down menu "pattern type" but all that allows me to select are edges and faces of the invisible hole. How do I select this? (What is it the Borg say??? "Assistance is futile..: or something.)
https://cad.onshape.com/documents/f6baa4466f87ddff8639e4da/w/bf8456ec5531b3b060ccfb07/e/12a1cc6e7b354b5963e3dea5
https://cad.onshape.com/documents/55898a5c58cd88ef5bf40186/w/4a7f404cdafbb78e9f3a1a16/e/9b7bf8b3f85b5f65416b749c
Twitter: @bradleysauln
Face pattern used to be a lot faster than feature pattern. Now feature pattern with "Apply per instance" turned OFF comes pretty close. Feature pattern with "Apply per instance" ON is much slower than face pattern (because that flag controls whether a regeneration is done for each instance of the feature).
Face pattern is more declarative of which exact faces you want to pattern, but feature pattern is more parametric in that if the selected feature changes its output, the feature pattern will pick up the change, rather than having to go in and select more/different faces.
Finished that sprocket and the chain fits perfectly. Try doing that with Tinkercad! (Which I actually did but it doesn't look nearly as nice.)
HWM-Water Ltd
