Featurescript - Sheet Metal Thicken
Austin_Keet
Member Posts: 6 ✭
Hello, I have a simple task. I am trying to create a sheet metal model by thickening it from a sketch in a featurescript. My FeatureScript creates the sketch correctly, however I am uncertain on how to use the sheet metal commands. Any guidance would be greatly appreciated!
Thanks for the reply mbartlett21. After looking through the library's sheet metal functions though I still don't understand. Where do I call sheetMetalStart? How do I do what I want to do after I call sheetMetalStart? If you have an example that would be great!
There is "SMProcessType.THICKEN" which looks like it might be what I want? But I have no idea how to assign the value of thickness that I want.
You can look up this link for the sheetMetalStart function
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/d72cde0155be691657609507?jumpToIndex=3679
Callit by insertingsheetMetalStart(context, id + "<b><i>SM_ID</i></b>", {<br> "process" : SMProcessType.THICKEN,<br> "regions" : <b><i>Sketch_Regions</i></b>,<br> "thickness" : <b><i>Sm_Thickness</i></b>,<br> "radius" : <b><i>Bend_Radius</i></b>,<br> "kFactor" : <b><i>K_Factor</i></b>,<br> "kFactorRolled" : <b><i>K_Factor_Rolled</i></b><br> })
1 -
Thanks! Helped a lot and I have it now.
In case anyone reads this later I did have to add "bends" : qSketchRegion(id+("sketch1")~j)), in the code. Let me know if I shouldn't have inputted the sketch as the query for bends though haha
sheetMetalStart(context, id + "SM_ID", {"process" : SMProcessType.THICKEN,"regions" : qSketchRegion(id + ("sketch1"~j)),
"bends" : qSketchRegion(id + ("sketch1"~j)),"thickness" : thickness,"radius" : 0.25 * inch,"kFactor" : 0.5,"kFactorRolled" : 0.5});1 -
@Austin_Keet
You probably had to supply a query for bends parameter, it should not be qSketchRegion(id + ("sketch1"~j)), even though it gets ignored. Please use qNothing() instead - it is exactly what it says it is.
1 -
@lana
Awesome, thanks lana1
