How do I tell if a cylinder is internal or external?
MBartlett21
Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
particulary for cylinder I beleve you could find for it cylAxis, cylRadius and cyl_face_normal_line, and based on the fact that onshape always return external normals define atestPoint = cyl_face_normal_line.origin + cyl_face_normal_line.direction * cylRadiusyou bacically translate the point of cyl face in the direction of external normall and then check if the translated point is on the cyl axis by test = tolerantEdquals(evDistance(...., testPoint, cylAxis), 0 )if test is true the cylinder is internal, else - external5
I could also use the code below, I just realised.
tolerantEquals(testPoint, project(cylAxis, testPoint));
It may be a little faster.0
