Thinner lines for visible edges.
arnor_eidssonarnor_eidsson Member Posts: 3 EDU
Hi
Is there any way to get thinner lines in drawing properties?
I need to set the thickness to 0.01mm or thinner to cut in the Epilog laser.
Can this be changed or do I need to fill out a request form?
Thank you
  • michael3424michael3424 Member Posts: 759 ✭✭✭✭
    I laser cut part designs by just right clicking on a face, exporting as a DXF, importing the DXF into my laser software and cut from there.  No issues at all with cutting.  Are you aware of that workflow?
